Ordered these 4 months ago but still waiting on the brake hose as it is back ordered from Honda. So I had a shop fabricated a set of stainless steel braided hose instead.
It’s not much, there’s still a lot of dust shield left.Can you provide a little more insight into how much you had to trim from the dust shields?
Thanks for the reply.It’s not much, there’s still a lot of dust shield left.
You just need to trim the outer edges off where it curls back to wrap around the outer edges of the smaller original rotors, and a couple small areas around the two bolt holes on the knuckle where the caliper attaches.
I’d say that overall, the trimming is pretty minimal, and not worth the hassle of pulling the knuckle/wheel bearing to swap over to the Type S dust shields.
It’s steel, I cut it with an angle grinder and hit the edges with a metal file to get rid of any sharp edges.Thanks for the reply.
What kind of metal is the dust shield made of? Pretty easy to trim? What’d you use to trim it?
Any chance of bending the curled edges instead of trimming?
Thanks, buddy. Appreciate the info.It’s steel, I cut it with an angle grinder and hit the edges with a metal file to get rid of any sharp edges.
No, the dust shield needs to be cut to make the necessary clearance for the larger rotors and calipers.
Finally got them installed tonight. I tore everything down after I got all the parts only to find out they sent me 2 front right brake pipes instead of a left and a right. The bags were labeled 46335-TGZ-A01 and 46336-TGZ-A01 however they were both the 46336-TGZ-A01 parts. I got them direct from my local Acura dealership too. Goes to show that you should always check your parts before you begin, even if it's from Acura...Any pictures with the new calipers?
that' hott!Update on the brake upgrade. I had a bit of a noise issue as described from the Acura TSB B23100A, so I decided to apply some brake grease to the pins and to the sides of the pads. Upon removing the caliper bolts, I found that they were not very tight. When I installed them, I had heard that the torque spec was 50lb-ft. After finding the bolts to be loose, I looked deeper for a torque spec and the most reliable info I can find is from BC Auto on YouTube. He states that the torque is 101lb-ft. I ended up torquing the brake calipers to this torque along with some blue Loctite and the noise is now gone. Anybody that may have torqued to 50lb-ft may want to check up on this to see if they have loosened up.
