Key battery replaced but still get warning
1 reading
21K views 3 replies 3 participants last post by  Gonzo
Have you replaced the battery in the for Driver 2 FOB ever? Wondering if that is low as well. Otherwise you can test the battery with a voltmeter to confirm its putting out the 3 volts (I believe it's 3 volts) as perhaps the new battery and the battery in Driver FOB 2 are both low. I have had some issues in the past were a new battery was old and not putting out low voltage.
If batteries check out, one other thing you can try (but you will prob lose you radio stations) is pull the negative connection off the battery for about 1 minute to "reset stuff" and see if that helps.
If same issue than I would think a trip to the stealer is in your future.
It never surprises me... for a 40K+ car how (me included) will try to save a couple of dollars only to end up costing more down the road. I guess by saving here and there in various degrees is one way some are able to get a 40K car.
