injen cold air intake issues
8.7K views 5 replies 4 participants last post by  Ryon527
#1 ·
I installed the injen cold air intake on my 2.4 and had major bogging issues and drops in the idle. It got so bad the car shut down and was having all sorts of warnings on the dash. Scared the **** out of me so bad I put the stock intake back on. All of the hoses were connected correctly. I'm trying to think what could be wrong..
Injen model #sp1676blk
23013-15 accord 2.4 4cyl
Everything bolts up like the accord
Thinking about it maybe I installed the maf sensor in backwards. Would that cause these issues? Thanks for the help.
#5 ·
Is your air filter the type that is oil coated? Often some excess oil will get on the MAF (Mass Air Flow) sensor and cause the situation you described. You might need to clean your MAF. If you decide to do this, be careful, they are fragile.
