The all new 2015 Acura TLX is the latest to come to the Acura Line Up. All new driver focused technologies perfectly blended with Acura’s engineering philosophy to create an inspirational well balanced machine. Uncompromised design, unrestrained feeling, putting exhilaration back into the drivers steering wheel, without compromising luxury.
It’s That Kind of Thrill.
TLX anticipates driver interaction with the vehicle. Whether it’s the P-AWS available on 4cyl and 6cyl front wheel drive models, or the v6 with SH-AWD, the TLX anticipates driver intentions and reacts seamlessly. It constantly monitors road conditions and driver input inspiring confidence behind the wheel of this vehicle. This car is very easy to drive and handles corners like no other sport luxury sedan.
Super Handling All Wheel Drive with Torque Vectoring capabilities was designed for superior handling on practically any road. SH-AWD also provides better traction in unfavourable weather conditions. SHAWD continuously directs engine power to the desired wheel to match driver inputs. The new system available on the TLX is 25% lighter than previous SH-AWD systems and now joins forces with the all new Agile Handling Assist.
Agile Handling Assist (or AHA) actively applies braking to any of the four wheels independently. This helps the TLX pivot through every corner more accurately allowing drivers to trace their desired drive line. Think of it like Brake Vectoring, just the opposite to what the SHAWD system is doing.
Precision All Wheel Steer (or PAWS) can adjust the toe angle of each rear wheel (by 6 degrees) for increased agility and stability. It can also help provide shorter braking distances by toe each rear wheel inwards resulting is a drag. Similar to how a skier turns the tips of his ski’s inwards to help slow down and gain control. PAWS also helps reduce turning radius and parking manoeuvring by angling each rear wheel based on driver inputs. The system works automatically and seamlessly to the driver.
TLX offers two engine choices, each designed with fuel efficiency and performance in mind. Both direct injected engines feature Variable Value Timing and Lift Electronic Control otherwise known as i-VTEC. This increases high rpm horsepower while maintaining a sufficient ample low end torque when excess acceleration is demanded.
3.5-litre V6 engines deliver 290HP and 267lb-ft of torque mated to a all new 9 speed automatic transmission made by german based company ZF. This transmission you will find in some competitors like the Range Rover Evoque, Chrysler 200 and Jeep Cherokee. V6 engines come standard with VCM technology. Variable Cylinder Management helps maximize fuel efficiency in V6 engines by allowing the engine to switch from 6 cylinders to 3 cylinders. This transition is seamless and unnoticeable to the driver.
2.4 litre inline 4cylinder engines deliver 206HP and 182lb-ft of Torque mated to an all new industry first 8 speed dual clutch transmission with torque converter. The transmission was designed in house by Honda Engineers and features a torque converter to make transitions more fluid and smooth versus a traditional dual clutch transmission. Our competitors have nothing like this in their vehicles.
Both TLX transmission feature Sequential Sportshift Paddle Shifters with rev-matching capabilities for quick manual style gear changes. V6 models smooth shifting 9 speed pushbutton automatic transmission marries performance and comfort while providing excellent fuel efficiency. The new 9 speed transmission compared to previous 6 speed transmissions used in TL is overall lighter, more powerful and efficient.
Integrated Dynamic System (or IDS) is standard on the all new TLX and gives drivers four different drive modes to choose from: Econ, Normal, Sport and Sport+. Econ boosts fuel efficiency, while sport mode raises shift points, dials up throttle response, stiffens steering feel and makes P-AWS and SH-AWD systems more aggressive while
Active Sound Control (ASC) tunes up natural engine notes. Sport + further enhances vehicle performance and response by blipping the throttle and rev-matching downshifts producing the ultimate driving experience.
There are always 4 ways home.
Design cues show Acura famed features like the brand exclusive Jewel Eye Headlights. Shorter overhangs, sculpted lines and a wide athletic stance, the all new TLX loves to show off its muscles. Get ready to trigger Road Envy.
Inside the luxurious cabin of the TLX, there is something you won’t notice. Sound. Pitch Perfect Silence. The Active Sound Control senses unwanted mechanical noise and combat it by emitting opposing frequencies into the cabin. Just like using BOSE noise cancelling headphones, the TLX reacts the same way by producing white noise to contest external sounds. Acoustically damped and thoroughly insulated with precisely sealing expanding foam, triple-sealed doors, and hydraulic engine mounts, the TLX houses its occupants in a Pitch Perfect cabin.
Surrounded by studio quality sounds, the available 10 speaker ELS Surround Premium Audio System has been developed by 7 time grammy award winning recording engineer Elliot Scheiner to give you the highest quality audio experience inside the all new TLX.
For the first time, Siri can now join you for the ride. The all new Siri Eyes Free allows compatible iPhone users to speak with their favourite digital friend. Make phone calls, play music, send and receive text messages, access maps and even ask for weather predictions all with the push of a button.
Not only is there one screen, or even 2, but actually 3 colour screens inside the all new TLX. You will find one colour screen infront of the driver displaying useful and most important information to the driver. This helps reduce the amount of time the driver needs to spend looking for information and more time keeping their eyes on the road.
This car is absolutely amazing and I have the pleasure of showing people just how great this product truly is. Acura has a winner here with the all new TLX. It would be my pleasure to assist you and show you all the reasons why you should buy yourself an all new TLX.
I have lots more information like this available.
