So is that how the push-start system works with the keys? If I don't have the keys inside the car it will shut off in 10 minutes? I thought it had some sort of range detection so if the keys are too far away from the car it will shout off. How does the car even sense that the keys haven't been near to the car for 10 minutes and then shut off. There has to been a radius detection programmed i'm guessing..
Welcome to the Forum! I am glad to see you made your first post.
Tells us more about yourself and your TLX dreams or experiences.
It's really the FOB that is the "key" to the car working. The internal key can be left at home. BTW, the internal key is the valet key or can be used to lock the glove compartment. If you don't have the FOB in the car, you cannot start the car.
Once the car is started and you throw the FOB out of the window as you drive away, the car will remain running. Once you turn off the engine you will not be able to restart it without the FOB.
I have heard instances where the wife had the FOB and was dropped off to do grocery shopping. The husband then heard the warning beeps but still was able to park the car. Once he stopped the engine he could not restart it. He went into the store to find his wife and borrow her FOB.
I have not heard of any instances where the car cut off after 10 minutes.
I also found out that if I leave the
car door open when the engine is running, leave the gear in park, and walk away, the car does not beep. If I just
close the door and walk away in the same manner otherwise, it will beep. I have only found that the beeps happen once.
The above is what I believe to be true. Let me know if you discover otherwise. The V6 may act differently than my I4.
