Out of the blue my trunk will not open. I used both of my key fob, inside door trunk release button, and also the outside trunk release button. Nothing works. I even check on the glove box and the switch is On. But for some reason when I am was sitting in my car and press the key fob or the button by the door, I can hear a soft sound of a "click" by the driver side footwell. Not sure what that might be. Only way I can open my trunk right now is the rear deck using the key to open it manually.
I'm thinking to see if I can try to disconnect the car battery and reconnect and see if that will reset everything.
Like to see if there any other insight out there that have this issue.
