This morning when I started the card it did not want to go into gear.
When it finally went into gear, it was stuck in 1st gear and acted like the Torque Converter was stuck together.
Shifting from Park to Reverse, it clunked and wen into gear hard.
Shifting into Drive it made a hard shift was stuck in Low Gear and would not shift at all.
So I turned the car off and waited a few minutes and restarted it and the car shifted normally.
Has anyone experienced this before?
That's a weird one. How many miles are on the car, and when was the trans fluid last changed?
(Not to make light of your problem, but this little guy popped into my head as I was reading.)
I have 57K miles and run ECON mode all the time.
This is the first time that anything has gone wrong and there were NO warnings or maintenance lights.
Have you shut down and restarted yet? Sounds like the typical computer "fix" solution, but if there was a glitch, it may get cleared after a restart!
Let us know what you find out.
Yep, it sounds like a "computer thing."
have this done
