Thank you so much. You described the movement of the transmission perfectly. lol I will see if they have a software update at the dealership. I don't know if I trust myself to reset my own transmission.TLX transmissions are known for their: Bucking, jerking or needing to look in the rearview mirror to see who hit you (type of feeling). You can return to Acura and complain and they will likely do a software update. You can also search on this board how to reset the transmission - often that can work wonders.
9speed trans sucks! No friction plates like other zf trans do to front compact design. Nothing can do out it.Does anyone else have a problem with their 2019 or 2020 transmission bucking in low gears?
Only two gears are dog clutches the other 7 use friction clutches.9speed trans sucks! No friction plates like other zf trans do to front compact design. Nothing can do out it.
Doesn’t work. Try on many tlx. 9speed is garbage.Heres the copy of the Acura TSB (Technical Service Bulletin) for the dealer to follow For transmission shifting.
8 speed Tlx trans are amazing. Haven’t seen any issue.Looking to get a 2020 I4 8 Speed DCT Front WD any known issues regarding this transmission?
I love my 2018 I4 8 speed Dual Clutch Transmission (DCT). It shifts so smoothly you never know that it has shifted except.by watching the TAC.Looking to get a 2020 I4 8 Speed DCT Front WD any known issues regarding this transmission?
