Speaker Sizes and Specifications:
The following info has been verified by googling eBay images, random posts over the year, and my own removal and inspection of my speakers in my 2017 2.4L 4 cyl. Base Model TLX. This information is prior to the 2018+ MMC (mid model change) and Pre-A Spec but I feel it’s highly unlikely the information is different.
ELS speakers are usually identifiable by an “ELS” sticker on them when removed. On a superficial level, aside from the “ELS” stickers, the speakers themselves look aesthetically identical to me.
Base models are a 7 speaker system
ELS is a 10 speaker system adding a front center speaker and two rear door card speakers
All models have the following
Two 1" 2 OHM 20 WATT tweeters*(A pillars)
Four 6.5" 2 OHM 20 WATT* speakers (front doors and rear deck)
One 8" 2 OHM 20 WATT subwoofer (rear deck)*
ELS Speaker in addition to the above
One 3.5” 2 OHM 12 WATT speaker (center dash)
Two 3.5” 2 OHM 12 WATT speaker (rear doors)**
* ELS 6.5” drivers don’t state wattage on the label but the assumption is made because everything else 6.5” is 20 watts.
** JL Audio Rob Haynes said rear door speakers are the same as center channel
Here is an official press release on the ELS speaker system. Claims it is "490 Watts" but the real RMS is most likely far far less. CLICK HERE TO VIEW PRESS RELEASE
Audio Wiring Schematics:
Acura currently provides free online wiring diagrams for our vehicles. They call them EWD (Electrical Wiring Diagrams). In my case, I find them by googling “2017 TLX EWD” which brings up the first mentioned website below. I have a BASE Model DCT 4 cylinder so that’s the one I select.
I pulled the rest of this useful assimilated info from EE4Life on another forum so thanks to him for consolidating and summarizing these other webpages. I/We should probably download these PDFs in the event they are removed from the internet.
2017 Acura TLX Electrical Wiring Diagrams (EWDs)
2017 TLX EWD
Examples of Commonly Used EWD Circuit Names for Powertrain Circuits
http://www.urvi.net/forumfiles/SB/BWW1313EM.PDF
http://techinfo.honda.com/Rjanisis/pubs/EM/BWW131/BWW1313EM.PDF
Examples of Commonly Used EWD Circuit Names for Body Systems
http://www.urvi.net/forumfiles/SB/BXX1313EM.PDF
http://techinfo.honda.com/Rjanisis/pubs/EM/BXX131/BXX1313EM.PDF
Electrical Acronym Definitions
http://www.urvi.net/forumfiles/SB/BYY1313EM.PDF
http://techinfo.honda.com/Rjanisis/pubs/EM/BYY131/BYY1313EM.PDF
EWD Main Electrical Symbol Definitions
http://www.urvi.net/forumfiles/SB/BZZ1313EM.PDF
http://techinfo.honda.com/Rjanisis/pubs/EM/BZZ131/BZZ1313EM.PDF
Factory Amplifier:
The factory amplifier is under the passenger side glove box fastened to the right side of the frame of the body. Drop the panel underneath the glove box to locate the amp. It’s a pain in the arse to work in this area, to the point that I paid a shop to tap into the middle harness (post factory amplifier) The following is an image of the factory amplifier in a BASE NON ELS V6 model which will look exactly the same as the BASE NON ELS 4 CYL.
What is circled in red are the stereo wires, meaning the wires coming from the stereo and into the factory amp.
The harness in the middle circled in green has the amplified audio signal wires that run to every speaker in the vehicle. Base and ELS models have the same exact harness shapes/pinouts.
In both Base and ELS models each and every speaker gets a set of amplified wires routed to them, including the tweeters. The tweeters in Base and ELS models just have resistors on them.
In the Base models post amplifier, as will be shown elsewhere, there is not an extreme level of EQ. No one with an ELS has chimed in or shown images/RTA of the EQ pre or post ELS amplifier so I don't know how different they are. But really all roads lead to Rome meaning if you are planning to use your own amplifier you will probably end up using a JL Fix82 or Fix86 after the factory amplifier anyways to completely flatten the factory amplifier EQ and sum the channels together for full range. Some have decided not to use the fix in order to keep factory ELS surround system processing and then reprocess that already processed sound with another DSP like the JL TWK. I will show you result charts of my Fix in the Base model. The pre amp signal in the base model appears to be full range to me, I've used a basic iPhone RTA to check the pre factory amp signals but not a real deal mic and rta to confirm.
Audio Schematic for Base model (NO ELS) looks like this. This is a screenshot of my 2017 Base 2.4L 4cyl DCT schematic showing “pre amp” channels (meaning before the amp) in red.
Notice what is circled in red. The colored lines in the schematic coming from the top of the image are directly from the factory stereo. In Base Models, there are only two sets of AUDIO SIGNAL wires coming from the factory stereo.
One set is the positive and negative for the Front Right channel.
Other set is the positive and negative for the Front Left channel.
If you look to the right of the schematic you will notice the base model does not have extra pre amplifier wires like the ELS stereo system will have coming from the factory stereo. Here’s another picture of this to give you a clear idea. The harness circled in green are wires coming from the factory stereo going to into the amplifier which include the audio wires. The rest of those spaces labeled “Not Used” are mostly used in the ELS model.
Now look at the following image of an ELS model. The ELS Models have many more sets of audio channel wires coming directly from the factory stereo. Look up your specific model to confirm.
Does the ELS system EQ inside the factory stereo before it even reaches the amplifier, or inside the amplifier? Don’t know as ELS owners who have modified their system have not confirmed or denied.
Again either way you’ll probably De-equalize the system and sum the channels using something like a JL Fix.
Bypassing The Factory Amplifier:
Yes. This can be done. In fact there is a T harness you can buy so you can easily test drive this set up without permanant soldering or cutting of cables. UNFORTUNATELY there is somehow not a T harness in the market yet for the POST AMP PLUG. Metra doesn't make it. Even though that plug shape has been in use in older Acuras (MDX) for a while now.
In my Base 2017 TLX 4 CYL I used the following harness and slightly customized it. It is meant for something else but I carefully searched the internet matching the plugs for a few months to find a harness that is exactly the same. It's called a "Fortin THAR-ONE-HON3" see the following images.
If you are interested in using the stereo signal before it reaches the factory amp, meaning you want to bypass, take note of what I did. If you disconnect the pre amp harness COMPLETELY then the stereo system will not work right. You need to keep some of the wires on the pre amp harness connected so the “ELS_DATE + -“ and the “ANC_” and the “RS485+-“ etc. REMAIN CONNECTED TO THE FACTORY AMPLIFIER. To avoid issues, you can only disconnect the audio channels. With the customized Fortin harness I was able to test the pre amplifier factory stereo signal. Here are some YouTube Videos showing this and you can read the notes on the youtube videos for more info. The base NON ELS vehicles only have two pairs of stereo wires coming from the pre amp. They are labeled "front left" and "front right". These pre amp wires have no volume control. They are pushing maximum output whether the stereo dial says 0-40.
https://www.youtube.com/watch?v=_yaktL3A5is
https://www.youtube.com/watch?v=ZEEoA2pnwtM
What did we learn. Well, the pre amplifier stereo signal is at max volume always. I believe they call it a CAN/BUS system. Meaning one of those ancillary wires, possible the "RS485+-" wires you keep connected to the amplifier are what control the volume. If you install your own system, you will either need to figure out use one of those compatibility devices like in other cars to interpret the CAN volume so you can adjust it (is this possible in our vehicle?), OR you will have to add your own dedicated volume knob from whatever amplifier / dsp processor. Here is the list of observations made.
1. Mute button on the steering wheel still works. Speaker went silent when hitting mute.
2. Volume control moving from 0-40 does nothing audible at all. Speaker played at the same exact volume regardless of the volume adjustment (even at zero) as indicated on the GUI.
3. Handsfree bluetooth calls worked properly - other person could hear/speak to me and I to them. (I had ANC disabled in the diag menus but plugged in)
4. Pre Amp AC voltage while playing a sine wave and pink noise measured at AC voltage at pre amplifier "Front Right" stereo wires range from 536mV - 791mV (.536 Volts to .791 Volts).
5. Used a free RTA app to roughly measure the sound coming out of the cheap speaker, I have a screenshot of it and it seems the whole range is there (the very bottom and very top of the range wasn't picked up by my iPhone and the cheap speaker may not have been putting it out, don't have an RTA so I don't know but it would be a decent to assumption that the full range is present).
6. You lose fader and balance.
7. You retain Skip controls on the steering wheel and display. Can pause and play using display.
8. Aux works
9. USB / iPhone port works
Question? Can I Amplify Post Amplifier without getting engine noise, high noise floor "shhhhh" sounds, engine whine "whirring up and down based on RPMs, or other sounds post amp:
Yes. You can. If you have noise issues you are doing it wrong. This has been my and others experience. I originally had a high noise floor myself, a shhhhhhhhh sound coming from the tweeters perpetually. I had to have the right eqiupment that accepted the proper voltages. In my build I ended up doing the following to styles without any issues and retaining stock volume control.
1. Factory stereo - factory amplifier - JL Fix86 - JL HD 900/5 - speakers
2. Factory stereo - factory amplifier - JL Fix82 - Helix DSP Pro MkII - JL HD 900/5 - speakers
If you are tuning with JL Fix there are some nuances you need to be aware of in order to avoid sound issues. I can outline these in another
Just Add A Subwoofer To The Stock System
Yea. You can do that. This is the most reported scenario. You want to tap a rear deck midwoofer and the rear deck subwoofer for a greater signal range to your aftermarket sub amp combo.
ANC “Audio Noise Cancellation” Renamed ASC “Active Sound Control”:
This vehicle uses an ANC system and microphones to cancel out sound waves and make the cabin of the vehicle quieter. Is it actually effective? This can be disabled in the diagnostic/developer menu as well as directly unplugged. The ANC unit is located underneath the glovebox. If you are modifying the audio system, you will need to disable this unit otherwise you can experience strange audio issues with an aftermarket system. Supposedly ANC is automatically disabled in Sports/Sports+ mode. This is located underneath the glovebox, See image below.
If I physically disconnect the harness from the ANC module / disable in the diagnostic menu will it affect bluetooth or other functions?:
No issues everything will work properly with the harness disconnected as well as disabled in the diagnostic menu.
If I disable ANC in the software menu will it stay off?:
It does for me and other people. I have checked several times an mine remains "off" in the software menu. Others report that it resets back on every time they check. Could be due to software / firmware differences between one vehicle to another.
Speed Volume Control
Volume will increase and decrease based on speed. Leave disabled to avoid issues with aftermarket system. This is located in the Sound Settings tab with the other EQ options.
Diagnostic Mode/Developer Mode
Access to this will vary by vehicle. You want access to this if you want to disable via software the ANC. There is also a setting in here dubbed "FLAT DSP" ON or OFF. No one has reported and tested what this did for them. But if it's as straightforward as it states it seems as though you can disable the software EQ curves the TLX has built in and might mean you don't need a DSP AT ALL. I discovered this later, and do not feel like trying to test this at the moment. But if you ever do please actually come back and tell us if it worked.
Hold Down ... Back + Menu + Audio
OR
Hold Down ... Back + Menu + Nav
THEN
Hold Enter and keep holding until you reach the second menu.
Then you can find ANC and disable. Just a heads up, your car is going to make a loud ish sound while disabling ANC. This is reported to be normal.
2017 TLX EWD
Factory Amplifier:
8. Aux works
OR
THEN
