I found some cool info about putting air the tires. I remember seeing a Honda commercial about this feature but I did not know it made its way to the TLX. I have not validated this fact.
Your vehicle gives you visual and audible alerts to help you adjust the tire pressure to its appropriate level. For your reference, the proper tire pressure levels are located on a label on the driver’s doorjamb.
1. Stop your vehicle with the tire that needs to be filled nearest to a tire air fill hose. Shift into Park (P). Turn the vehicle off.
2. Turn the vehicle on. The assist system is activated for 5 minutes.
3. Attach the air hose to the valve stem, and begin to fill the tire.
While inflating: The system beeps and the hazard lights flash once every 5
seconds as tire pressure changes while below the correct pressure.
When the correct pressure is reached: The system beeps and the hazard lights flash continuously for 5 seconds. Stop filling the tire.
If you over inflate: The system beeps and the hazard lights flash twice every 5 seconds.
Tire Pressure Monitoring System (TPMS) | 2015 Acura TLX | Acura Owners Site
