When the car is idle and in park, the RPMs will jump from a "normal" 800 or so, up to 1,500, and then throttle back down to 800. For no reason. I'm not even touching the gas pedal.
Also, when driving and coming to a stop, the throttle will also "race" as the car downshifts. It's almost as if you're stepping on the gas while braking. I know that the RPMs adjust as the car downshifts, but you can definitely feel the car almost "fighting" itself by accelerating and braking at the same time. Very weird, and disconcerting.
Finally, when you just start out and take your foot off the brake, the car will accelerate to about 10 mph, and even change into second gear - without even touching the gas pedal.
This is not normal. Anyone else have this issue? V6 awd advance
