1 - 17 of 17 Posts
The radio in my '16 Tech powers off as soon as the ignition is cut. From my research, this is apparently "normal" for the TLX and other Japanese-designed cars. In our Jeep and the majority of other modern vehicles, the radio will play until a door is opened or for a pre-determined (or user-programmed) amount of time.
In my '03 F150, I tapped into the battery-saver circuit and used a relay to power the switched hot lead on my radio to achieve this function. Does anyone know if there's a way to do this simply on the TLX?
If you search Accessory mode you’ll find a couple of different ways. You can hit the power button without putting the car in Park when you stop. The radio will stay on and the car will still go to Park. The other way is shutting the car off as you normally do and then hit the Start button without putting your foot on the brake.
My 2014 F-150 keeps the radio on until the driver door is opened.
I found both of those workarounds listed, though the first one doesn't work in mine. The radio shuts off when Park is engaged.
I'd love to find a transparent solution like I did in my truck.
Yep. Just like lots of other vehicles made in the last ten years or so. FWIW, I see the same complaint about Toyota and Mazda vehicles, too.
Based on these wiring diagrams, it looks like it may be relatively simple to implement the same "fix" as I did on the F150 by pulling a signal off one of the power window switch wires, and using that to switch a hot to the radio's "ACC" control wire (light blue, highlighted).
On the flip side my wife's Q5.... she can't always tell when the car is actually off... between the radio always on and the LCD instrument panel... I too wish you go turn off the car and keep the radio on instead of having to "reboot".
I also have had a learning curve with the electronic shifter (V6) and the push button start.
Car wash: Neutral, but need to shift to P to get it back to D to drive away after the wash. Always some anxiety exiting the tunnel. (Yes I no longer hand-wash).
Leave the Radio on: I shift to N and then within 5 seconds hit the push button start. This leaves the radio on, but the dash will revert to a simple display, just saying shift to P to power OFF (or something like that). The key here is "within" 5 seconds.
...Car wash: Neutral, but need to shift to P to get it back to D to drive away after the wash. Always some anxiety exiting the tunnel. (Yes I no longer hand-wash).
Hi Gary no need to place in P first to get out of car wash mode... gently push brake pedal (not enought to apply brakes just turn on brake lights) then you can place into D from N.
I never knew that about accessory mode... I will try that.
@Gonzo I'll try that tip: gently push brake pedal (not enough to apply brakes just turn on brake lights) then you can place into D from N.
We got about 2-3 inches of wet snow last night. The salt will be everywhere today. And it will get to mid to upper 50's tomorrow. So the car washes will be mobbed.
I tried your trick to keep accessory mode on... worked! Just stinks that you have to keep it in neutral but I can live with that.
Hey its gonna be 50 tomorrow.... I'm seeing a nice day for a hand wash! Heck I hand washed mine today... 38°! EEEK!!!!!
I also engage the parking brake (while in N)!
I know this is an old thread, but adding a method to retain ACC power when turning off the car in case someone searches the subject. Note, mine is a 2.4 Tech with the 8DCT and physical gear selector; the method I describe below won't work on the V6 TLXs with the push-button type gear selector .
On my 4 cyl TLX:
  1. I put the car in park as usual (can apply the parking brake or not)
  2. With my foot OFF the brake pedal, I depress the gear shift/select lock button (it'll only go in slightly when the brake pedal is not depressed)
  3. Then use my other hand to push the Start button once
  4. The car is in park and the engine is off, but the ACC is on.
To turn it all off: without pressing the brake pedal, you need to press the Start button twice (once to go to "ON" mode, and again to turn it off).
I'm going by memory, so hope it's correct as I've laid it out. It's just another workaround to a less than ideal implementation of ACC mode on the TLX.
Discussion Starter · #14 ·
It's not that old. :)
I tried this yesterday, and it works as long as I hold the trigger on the shift handle. As soon as it's released, accessory mode shuts off. :confused:
That's unfortunate... not sure if I had it down 100% as written (I rarely use the car these past few months and it had been a while since I used the method). I replicated the process this morning and captured it on video linked below - I wasn't sure how best to share/upload the video so hope it works (& helps)!
Discussion Starter · #16 ·
Yep. Nope.
Perhaps you have a sticky trigger switch. :)
Hmmm, that's slightly disappointing. Not sure if it's a US/Canada thing ...or as you say, sticky button...
1 - 17 of 17 Posts
