1 - 5 of 5 Posts
2019 Acura TLX Base
Have a new to me 2019 Acura TLX Base....
Codes point to a problem with the Gas Cap.. but I don't have a gas cap.
Driving and random go this check engine light.. Any ideas?
26315
26316
26317
I just recently went through the very same situation.
After what I have read on this forum, I had my battery check at 2 different places and my battery check BAD at both. I bought a new battery and installed it.
I haven't had the problem since.
2019 Acura TLX Base
I been also reading and also hearing fuel filler neck needs to be replaced… the car is going to the dealer on Friday to change out the fuel pump (recall).. I will have them look at this as well
PROBLEM SOLVED.
The fuel filler neck need to be replace since it was stuck open.
I think is the part.
It is great that you got it taken care of while still under warranty.
As for the bad battery problem I had, you would have thought that Acura would have put in a "Check Battery" warning. I am sure that it sensed the battery problem earlier when I was getting the partial shutdowns. That way it could have been fixed before the dreaded "Complete System Shutdown."
1 - 5 of 5 Posts
