1 - 18 of 18 Posts
I purchased my 2015 TLX around October of 2014. This means the battery is probably right at 4 years old. With winter coming, I don’t want to get stranded and would rather replace the battery on my terms and time. Not to mention the numerous 2015 owners here who have already had to replace their battery. Mine was likely at the end of its life too.
I stated looking for an Optima battery. I went to their site and used their application guide. It did not show a battery for my TLX. I thought there might be a mistake, so I called Optima technical support and asked them. They told me that they don’t make a group 48 battery and that I would need to modify my battery box or choose a smaller battery. It wasn’t that important to me to have a RED or YELLOW top battery at twice the price.
I started looking around and found Sam’s Club. They carry Duracell brand batteries. They have a Group 48 (H6) AGM battery on sale for $139.76 with a 3-year free replacement with free installation. Item number #136048 , Model # 48(H6) AGM.
I asked the service advisor at Sam’s if they install the battery in a way so that I don’t lose my presets? He said they will reset the clock for me. I told him I’ll install the battery myself.
The new battery was a perfect fit. The only tool you need is a 10mm deep well socket for both the hold down clamp and battery terminals.
As a general rule for most all cars; to avoid having to reset the seat memory, radio presets and other devices, I always use my jumper box when installing a new battery. I attach my jumper box + to + and – to – leaving room to remove the battery terminals. Then when I remove the battery terminals, the car still has it’s necessary 12 volts to keep everything powered. From the cars perspective, it never lost its 12 volt signal and all presets stay the same. Heck, it took me about a week to get my seat memory just perfect. Don’t want to have to do that again!
In case anyone is interested, here are the specifications on this battery.
20-amp hour rate:70
Battery electrolyte composition: Glass Mat
Battery end type: Top post
Battery purpose: Starting lighting instrumentation
BCI group size: 48
CA at 32 degrees F: 875
CCA at 0 degrees F: 760
DIN code:H6/L3
Freight class: 65
Polarity: Right positive
Reserve capacity: 120
Terminal type: DIN
Winter is right around the corner and if anyone thinks like me that their battery is on it's last leg, probably best to replace now instead of getting stuck.
In the past I have gotten about 5 years out of the battery... I think if you made it though the summer heat winter is no problem... I say keep it for another season... go for it.
Wait can you clarify this... by jumper box... do you mean you just connect the new battery with jumper cables to battery cables in the car or....?
Sorry if I was not clear enough. When I change a battery I always use a jumper box or else wish I did afterwards trying to reset everything. Here is how I do it.
1) Attach jumper box cables to car leaving enough room to get to the 10mm bolts on battery terminals
2) Turn on jumper box
3) Remove battery cables from battery
4) Replace battery
5) Attach battery cables onto new battery with 10mm socket; tighten
6) Turn off jumper box and then remove jumper box
NOTE: There are some special tools designed to do the same thing to keep the memories in your car with a cigarette plug adapter and 9v battery. I've heard of a few occasions where the 9v battery is not enough to keep the 12v memory. I prefer the jumper box method.
Ah that makes sense.... good tip. I've tried the 9 volt battery in the cigarette light in another car but it didn't work... the jump box / charge method should work fine. If you just a jumper box / charger just set to slow charge.
Great tip!
Thread resurrection, but does anyone know if the I4 will accommodate a Group 48/H6 in place of the specified Group 35? Thanks.
My quick query at Interstatebatteries.com has the I4 using the Group Size 35 whereas my v6 requires the Group Size H6. Now you are asking if that size will "fit" in the I4.
A simple view of the engine compartment from the Owner's manual does show that there may NOT be room for the larger battery in the I4.
25058
25059
"Yep" to all that, Gary. Hence the question. My bet is "no," as well, but alternately, there may be a larger capacity battery that fits, instead. I'll be researching further, and will post up any favorable results.
When it’s time to replace my battery, I’ll be installing an XS Power. Just checked and they make a 48.
2015 TLX Advance V6
20-amp hour rate:70
BCI group size: 48
DIN code:H6/L3
Freight class: 65
Terminal type: DIN
Good morning,
I just had my battery changed out at Auto Zone and I am unable to access the infotainment system, the message states to hold down power button for 2 seconds to bring it up but that failed.
The message also states if that does not work enter the code #. Do you know where I can find the code #. I have a 2015 TLX Advance V6 front wheel drive.
Thanks
2015 TLX Advance V6
Good morning,
Thanks
Please disregard, I have left a message with Acura. I bought the car used and there are no nav. and radio cards with codes or located in the glove box. Thanks
OK to be more direct,
1. Go to Information Functions in your Navigation Manual.
2. Under System Device Settings it shows what steps to take to display the system information screen.
3. That Device ID is what they call DEVICE SERAIL NUMBER.
4 That is what you input for Device Serial Number.
2015 TLX Advance V6
On Monday morning an Acura rep helped me locate the serial #, the process took less than 5 min. All presets were preserved. Thanks for the info.
I’ve got to install a new battery in the next couple of days. I have an xs power being delivered Monday. I just moved to Chicago and my battery is almost 4 years old. We’re having overnight lows in the low single digits right now, it took a few tries to get the car started this morning- I almost thought it wasn’t going to make it.
Glad my dad said something to me about this radio code thing..l I was unaware of it.
I did my battery install today. Not sure why, but it gave me the option to simply hold the power/volume button for 2 seconds and it reset the code on its own. I don't have any radio presets- as I don't listen to the radio- so I have no idea if it saves presets or not. I did notice that the mpg average reset. Don't really care about that either.
1 - 18 of 18 Posts
