I am finding the Nav turn-by-turn guidance volume to be difficult to hear when music on a bit louder. Already cranked to max at 11 but problem seems to be that it does not lower music/radio volume enough when prompting, as my previous vehicle did.
I missed that. Sorry. Strange how the volume at max still doesn't come through loud enough. It would be interesting to see if others have the same issue or if it's just something with your particular car.I am finding the Nav turn-by-turn guidance volume to be difficult to hear when music on a bit louder. Already cranked to max at 11 but problem seems to be that it does not lower music/radio volume enough when prompting, as my previous vehicle did.
I caught the Guidance voice when I was changing the volume and the Guidance Voice changed!! Kinda cool!:laugh:Owner's Navigation Guide said:Guidance Volume
If you set Guidance Volume to 0, you will not hear route guidance or voice command confirmations. You can also adjust Guidance Volume by rotating the volume knob while the route guidance or voice command confirmations is announced.
If you then select Voice in the Map Menu, you will hear route guidance at the default volume.
Interface Dial Feedback
You can use this feature to minimize the need to look
at the screen while operating the Interface Dial.
It is cool.I may be late to the thread, but as a new owner, I'm finding a few things out that I missed in the manual.
Directly from the Nav Guide (p 27):
I have a 2015 and music volume lowers whe she speaks.. or it use too . Now there is no soundI missed that. Sorry. Strange how the volume at max still doesn't come through loud enough. It would be interesting to see if others have the same issue or if it's just something with your particular car.
