61 - 80 of 84 Posts
I just replaced mine - I purchased the "A001" version, and it seems like it has only one view. I just ordered the "A011" version, and will report back if I have the three views (I do use all three, so I want to get back that original functionality).
Thank you all for the instructions! It was super easy to replace. A few notes-
1- The clips holding the outside piece of trim (The piece you pull down after removing the license plate) are held with fairly robust clips - They will take some prying without breaking. I used a guitar pick starting at the center (Thin/plastic didn't scratch anything), and worked my way to each side - There are two clips on each side.
2- The clips holding the inside cloth trim are VERY fragile - It works best to use a small flat head screwdriver to "Pop up" the top to release them - They are two pieces that lock in place when the top is pushed down. If they break, they are probably still usable, but a bit tricky to push back in place.
3- The electrical connectors are held together by a small "Button" at the top over the piece that will be removed. The camera connector assembly is held in place with a clip holding it to a metal "Ear" in the door frame - It's easy to remove it, which gives you better access to that button.
I just got it installed. Image quality is much better especially at night. But it seems to have a weird circle on top and the yellow guide On the screen is not accurate anymore. Anyone got this problem?
25069
Vehicle Car Multimedia Technology Screen
The accuracy of the lines is related to the alignment of the camera. Are you sure the camera was fully seated and the screws were all tight, and the camera assembly was fully snapped in place? There is a very tiny but of play; perhaps some slight camera aiming will solve it?
It looks to me the view is more zoomed in
Maybe i put the camera upside down? I feel like it was assembled very securely.
Hi guys. Here is an update on my backup camera. I took out the camera assembly (getting to it was very easy) but I couldn’t take the camera apart. It was impossible. So I looked up the part number online and it was very close to CRV except for the last four digits. Picture also looked identical. I found CRV camera on eBay for $28 and gave it a try. I also noticed there are a lot of complaints about foggy backup camera for CRV so I figured Honda uses same for majority of their vehicles. It took two weeks for the camera to arrive and moment of truth.... it was perfect fit and it worked!!! Only thing doesn’t work was different views settings but I don’t think I ever used different views so doesn’t bother me. Spent less than $30 vs $315 dealer quoted me for the part so I am very pleased. Here are some pictures including before and after.
Hi. Do you have the link from eBay for the camera?
Thanks
Thanks to all for the posts regarding this issue. The dealer wanted $420 to replace the camera. I spent less than $30, and everything works perfectly now. Can’t thank you guys enough...
I investigated and the camera is properly seated. The view is shifted to the left which made the guidelines inaccurate. Im not sure if it is just me or everyone else have this problem?
i got the A011 version.
anyone got this problem? Should I do an exchange?
Wonder if the camera is defective. For $30 try another one.
Hm. After a few uses I think the view is not shifted to the left but just more zoomed out due to CRV camera has wider view. It makes the TLX guidelines become bigger. It is most noticably off in normal view.
I’m trying to find a way to recalibrate that guideline but the dynamic guideline is pretty hard to do as it has 5 settings each left or right turn
FYI Ive now gone through 2 replacement cameras for my 2015 TLX, replacement model number 39530-T0A-A011-M1 and both cameras display the image upside down.
Ill try the 39530-T0A-A001-M1 next but this is becoming a pain in the ass.
There is only one way this fits, trust me, I even managed to split one open to try and flip it inside the housing.
25167
What happened with this man? Mines upside down, the replacement as well.
Anyway guys here's an update as I finally got my camera and installed it and it worked!! I bought this from Aliexpress US $17.28 25% OFF|39530 T0A A001 M1 Rear View Back Up Park Assist Camera for 2012 2013 Honda CR V|Vehicle Camera| - AliExpress it was like $28 CAD at the time and I got it a bit late but I guess it was delayed due to COVID-19. Anyway, I installed it today and my camera now works perfectly fine! The guided lines maneuver as well and I can change the angles as well. The toughest part for the replacement was plugging back the cable into the slot because the cable is very short and you don't have enough space to work with so I used two long screw drivers to guide it into the slot.
I have a 2015 TLX, I found a camera removed from a 2016 on eBay, and replaced it. I used this video to show how to do it, I’m glad I didn’t bring it to a shop to do it, took about 10 minutes.
are the guidelines accurate?
I find the CRV camera to have very wide viewing angle which is good that I can see more of the back, but the guidelines are not accurate anymore
Hi Jimmy! I am also having the same moisture problem with my 2015 TLX Back up camera. Can you please tell me which CRV camera you bought? Thanks
39530-T0A-A011-M1 with 3 view most people in this post I read picked this but don’t know which eBay seller are best . Update post for for best seller please
39530-T0A-A001-M1 with 1 view
Hi guys. Does anyone have instruction how to disassemble back up camera? It was getting fogged up when it rains and worked fine during sunny days. Now my warranty expired and permanently fogged up now can’t see anything. Any help would be great. Thanks.
I found the camera brand new at Amazon, super easy to install works great with the multi view option and cost nothing comparing used car parts or dealer
Here is the link:
61 - 80 of 84 Posts
