Preferably black, anyone got the plug?
That looks great. Better then chrome beak.Once you go black, you never go back!
All that to replace the beak section???? One would think it can all be done from under the hood without having to tear apart the entire front end. Makes a wrap or plastidip that much more appealing.I did this modification when my TLX was only a few weeks old. I wanted something that would make it stand out from the other TLX's but not to radical. Because of the radar sensor that sits behind the grill, you must be careful about adding anything metallic in front of it. This would include any metallic paint. Also keep in mind that the beak for the vehicles with radar are different than those without radar (in case you want to get a second beak). In one of my pictures you can see the square 3" x 5" radar sensor that sits behind the grill. If you have any specific questions about the mod, let me know. Yes, a lift makes the job easier, especially on your back, but it can easily be done without a lift.
What MTD says is true and you can wrap your grill for around $100 without anything needing to be taken apart.Thats a tons of work to black out the grill. You can have it wrapped for prob $100 and nothing needs to be taken apart to do it.
Good point. Matching paint brings a whole other dimension into it. If you want straight black (like I would), I'd consider wrap or plastidip or similar. What'd I'd really want to do is black out all the chrome on the car. But I don't have the time for that, especially the window trim which seems like it would be pretty difficult.What MTD says is true and you can wrap your grill for around $100 without anything needing to be taken apart.
I considered wrapping at the time but this was not what I wanted. I wanted a more permanent mod with paint that matches EXACTLY the same as my entire vehicle. That is what I wanted and what I have.
It all depends on what you want.
Probably but now that you bring that up it makes me wanna do some research on itProbably a dumb question, but did "Blacking out" cars originally come from being a counter measure against laser guns? The concept is to reduce the reflective surfaces.. The grill being the biggest usually and the most reflective.
