Status
Not open for further replies.
1 - 1 of 1 Posts
TSB 14-016 - 2015 TLX: TQI and New Model Service Information
Applies To: 2015 TLX - 4-Cylinder 2WD P-AWS 8-Speed DCT - Base, Technology
2015 TLX - 6-Cylinder 2WD P-AWS 9-Speed A/T - Base, Technology, Advance
2015 TLX - 6-Cylinder AWD SH-AWD Idle Stop 9-Speed A/T - Technology, Advance
http://www.urvi.net/forumfiles/SB/B14-016.PDF
TSB 14-017 - 2015 TLX: TQI of the Navigation System
Applies To: 2015 TLX - All with Navigation
http://www.urvi.net/forumfiles/SB/B14-017.PDF
TSB 14-025 - Timing Belt Chirps
Applies To: 2015 TLX - 2WD - From VIN 19UUB2...FA000001 thru 19UUB2...FA025139
2015 TLX - AWD - From VIN 19UUB3...FA000001 thru 19UUB3...FA010310
http://www.urvi.net/forumfiles/SB/B14-025.PDF
TSB 14-036 - Noncompliance Recall: TLX Certification Label
Applies To: 2015 TLX - V6 AWD - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-036.PDF
TSB 14-037 - Client Satisfaction Improvement Campaign: Update for 2015 MDX and TLX ODMD (Vehicles with Navigation)
Applies To: 2015 TLX - All with Navigation - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-037.PDF
TSB 14-048 - New Warranty Instructions for TPMS-Related Repairs
Applies To: 2015 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B14-048.PDF
TSB 14-050 - Safety Recall: Transmission Does Not Engage Park
Applies To: 2015 TLX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-050.PDF
TSB 14-054 - Product Update: Cross-Traffic Monitoring System – No Audible Alert
Applies To: 2015 TLX - Tech - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B14-054.PDF
TSB 15-006 - Clunk From Front Suspension When Driving at Low Speed Over Bumps or Turning
Applies To: 2015 TLX - L4 - From VIN 19UUB1F..FA000001 thru 19UUB1F..FA005784
2015 TLX - V6 without SH-AWD - From VIN 19UUB2F..FA000001 thru 19UUB2F..FA008008
2015 TLX - V6 with SH-AWD - From VIN 19UUB3F..FA000001 thru 19UUB3F..FA001079
http://www.urvi.net/forumfiles/SB/B15-006.PDF
TSB 15-017 - AcuraLink System Status Indicator Is Red and DTC B1403 Will Not Clear
Applies To: 2015 TLX - 2WD L4 with navigation - From VIN 19UUB1...FA000001 thru 19UUB1...FA007105
2015 TLX - 2WD V6 with navigation - From VIN 19UUB2...FA000001 thru 19UUB2...FA009308
2015 TLX - SH-AWD V6 with navigation - From VIN 19UUB3...FA000001 thru 19UUB3...FA001517
http://www.urvi.net/forumfiles/SB/B15-017.PDF
TSB 15-021 - Transmission Slips or Shifts Hard When Cold
This TSB is replaced by TSB 17-015 - 8-Speed Transmission (DCT) Has a Bump or Hard Shift When Coming to a Stop
Applies To: 2015 TLX - ALL L4 - From VIN 19UUB1...FA000001 thru 19UUB1...FA011573
http://www.urvi.net/forumfiles/SB/B15-021.PDF
TSB 15-024 - Product Update: PCM Software Does Not Meet OBDII Regulations
Applies To: 2015 TLX - L4 with 8-speed transmission - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-024.PDF
TSB 15-027 - LKAS Does Not Keep Vehicle in Detected Lane
Applies To: 2015 TLX - With Technology Package - ALL
2015 TLX - With Advance Package - ALL
http://www.urvi.net/forumfiles/SB/B15-027.PDF
TSB 15-034 - Product Update: Vehicle Shifts into Neutral and MIL Comes On with DTC P0657
Applies To: 2015 TLX - With 9-speed A/T - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B15-034.PDF
TSB 15-038 - Hesitation, Surge, High Idle, or Auto Idle Stop Does Not Work
Applies To: 2015 TLX - V6 with A/T - ALL
http://www.urvi.net/forumfiles/SB/B15-038.PDF
TSB 15-039 - Transmission End Cover Leaks (9-Speed A/T)
Applies To: 2015-18 TLX - ALL with 9-speed A/T - ALL
2019 TLX AWD - 9-speed A/T - From VIN 19UUB3F..KA000002 thru19UUB3F..KA002947
2019 TLX 2WD - 9-speed A/T - From VIN 19UUB2F..KA000001 thru 19UUB2F..KA003475
http://www.urvi.net/forumfiles/SB/B15-039.PDF
TSB 15-040 - Firm 2nd to 3rd Gear Upshifts Under Certain Driving Conditions
Applies To: 2015 TLX - V6 2WD - From VIN 19UUB2...FA000001 to 19UUB2...FA021489
2015 TLX - V6 SH-AWD - From VIN 19UUB3...FA000001 to 19UUB3...FA007728
http://www.urvi.net/forumfiles/SB/B15-040.PDF
TSB 15-041 - Multiple Indicator Lights Come On, Stuck in 4th Gear, and Temporary DTC P0714 is Set
Applies To: 2015 TLX - V6 with 9-speed A/T - ALL
http://www.urvi.net/forumfiles/SB/B15-041.PDF
TSB 15-042 - Fluttering Noise From Behind Dashboard
Applies To: 2015 TLX - L4 2WD - ALL - From VIN 19UUB1...FA000001 thru 19UUB1...FA022558
2015 TLX - V6 2WD - ALL - From VIN 19UUB2...FA000001 thru 19UUB2...FA022490
2015 TLX - V6 AWD - ALL - From VIN 19UUB3...FA000001 thru 19UUB3...FA008262
http://www.urvi.net/forumfiles/SB/B15-042.PDF
TSB 15-050 - Multiple Indicators are On with DTC U129D
Applies To: 2015 TLX - L4 2WD - From VIN 19UUB1...FA000001 thru 19UUB1...FA026785
2015 TLX - V6 2WD - From VIN 19UUB2...FA000001 thru 19UUB2...FA023882
http://www.urvi.net/forumfiles/SB/B15-050.PDF
TSB 16-008 - High Pressure Fuel Pump Chirps
Applies To: 2015-18 TLX - ALL with V6 - ALL
http://www.urvi.net/forumfiles/SB/B16-008.PDF
TSB 16-009 - Vibration Felt in Floor at Highway Speed
Applies To: 2015 TLX - AWD - From VIN 19UUB3F..FA000001 thru 19UUB3F..FA004363
http://www.urvi.net/forumfiles/SB/B16-009.PDF
TSB 16-011 - Product Update: Monroney Label (Hawaii)
Applies To: 2015-16 TLX - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-011.PDF
TSB 16-012 - Transmission Function Improvements: Sensation of Surge While Braking, Slow Downshift Response at Low Engine Speeds, DTC P2638 and Other Listed Symptoms
Applies To: 2015-16 TLX - V6 2WD with 9-speed A/T - From VIN 19UUB2...FA021489 and later
2015-16 TLX - V6 AWD with 9-speed A/T - From VIN 19UUB3...FA007728 and later
http://www.urvi.net/forumfiles/SB/B16-012.PDF
TSB 16-039 - Buttons Sticking on Audio-Navigation Unit (Day/Night, Settings, Navi or Audio)
Applies To: 2015-16 TLX - ALL - ALL
2017 TLX - All except base - ALL
http://www.urvi.net/forumfiles/SB/B16-039.PDF
TSB 16-041 - REPLACE 12 VOLT BATTERY Message Will Not Clear After Battery Replacement
Applies To: 2015 TLX - 4 cyl only - ALL
http://www.urvi.net/forumfiles/SB/B16-041.PDF
TSB 16-057 - Vibration Felt In Front Seats and Floor at Highway Speeds
Applies To: 2015-16 TLX - ALL V6 - ALL
http://www.urvi.net/forumfiles/SB/B16-057.PDF
TSB 16-058 - Rubbing, Popping or Clicking From Front Door When Opening
2017 TLX - L4 2WD - From VIN 19UUB1...HA000001 thru 19UUB1...HA001763
2017 TLX - V6 2WD - From VIN 19UUB2...HA000001 thru 19UUB2...HA000874
2017 TLX - V6 AWD - From VIN 19UUB3...HA000001 thru 19UUB3...HA000600
http://www.urvi.net/forumfiles/SB/B16-058.PDF
TSB 16-075 - Safety Recall: 2015 TLX V6 A/T Sensor Cluster Crimp Failure
Applies To: 2015 TLX - V6 with A/T - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B16-075.PDF
TSB 17-003 - AcuraLink Sending Excessive Notifications for Low Power
Applies To: 2015 TLX - Tech/Adv - ALL
2016 TLX - L4 2WD Tech - From VIN 19UUB1...GA000001 thru 19UUB1...GA009841
2016 TLX - V6 2WD Tech/Adv - From VIN 19UUB2...GA000001 thru 19UUB2...GA009123
2016 TLX - SH-AWD Tech/Adv - From VIN 19UUB3...GA000001 thru 19UUB3...GA002269
http://www.urvi.net/forumfiles/SB/B17-003.PDF
TSB 17-011 - Product Update: TLX 9-Speed Transmission Warmer
Applies To: 2015-16 TLX - All with 9-speed A/T - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B17-011.PDF
TSB 17-012 - Product Update: TLX 9-Speed Transmission Warmer (Transmission Previously Replaced for Transmission Warmer Leaking)
http://www.urvi.net/forumfiles/SB/B17-012.PDF
Applies To: 2015–17 TLX - ALL L4 8-Speed Dual Clutch Transmission (DCT) - ALL
http://www.urvi.net/forumfiles/SB/B17-015.PDF
TSB 17-027 - Warranty Extension: TLX Transmission Chirps During 3-4 Shift, Poor Shift Quality, or Engine Overheats Because of Defective ATF Warmer
http://www.urvi.net/forumfiles/SB/B17-027.PDF
TSB 17-030 - Water Pump Seizes or the Drive Belt Is Shredded
Applies To: 2015-16 TLX 2.4L - ALL - ALL
http://www.urvi.net/forumfiles/SB/B17-030.PDF
TSB 17-034 - MIL Comes On with DTC P0430 (Front Bank Catalyst System Efficiency Below Threshold [Bank 2])
Applies To: 2015-17 TLX - V6 Only - ALL
2018 TLX - 2WD (V6 Only) - From VIN 19UUB2...JA000001 - 19UUB2...JA003458
2018 TLX - SH-AWD - From VIN 19UUB3...JA000001 - 19UUB3...JA001898
http://www.urvi.net/forumfiles/SB/B17-034.PDF
TSB 18-014 - Clicking from the Power Seat While Using the Height or Tilt Adjustment
Applies To: 2015-18 TLX - ALL with 10-way driver's power seat; ALL with 8-way passenger's power seat - ALL
http://www.urvi.net/forumfiles/SB/B18-014.PDF
TSB 19-003 - MIL Comes On with DTC P0716
Applies To: 2015 TLX - V6 2WD with 9-Speed A/T - From VIN 19UUB2...FA021489 and later
2015 TLX - V6 AWD with 9-Speed A/T - From VIN 19UUB3...FA007728 and later
2016-17 TLX - V6 with 9-Speed A/T - ALL
http://www.urvi.net/forumfiles/SB/B19-003.PDF
TSB 19-011 - Safety Recall: 2016-18 MDX and 2015-19 TLX V6 Fuel Pump
Applies To: 2015-19 TLX V6 - ALL - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-011.PDF
TSB 19-012 - Knocking or Clicking From Engine During Cold Startup
Applies To: 2015-18 TLX - L4 - ALL
http://www.urvi.net/forumfiles/SB/B19-012.PDF
TSB 19-017 - Buzzing or Whining When Adjusting Front Seat Forward and Backward
Applies To: 2015-19 TLX - ALL - ALL
http://www.urvi.net/forumfiles/SB/B19-017.PDF
TSB 19-033 - Warranty Extension: B-588P Obsidian Blue Pearl or Fathom Blue Pearl Paint
Applies To: 2015 TLX - All vehicles painted B-588P - Obsidian Blue Pearl or Fathom Blue Pearl - Check the iN VIN status for eligibility
http://www.urvi.net/forumfiles/SB/B19-033.PDF
TSB 19-049 - MIL Comes On with DTC P0420
Applies To: 2015-17 TLX - ALL with V6 - ALL
http://www.urvi.net/forumfiles/SB/B19-049.PDF
TSB 19-059 - Service Manual Update: Evaporative Emission (EVAP) Control Diagram
Applies To: 2015-20 TLX
http://www.urvi.net/forumfiles/SB/B19-059.PDF
Last updated 26 Nov 2019
1 - 1 of 1 Posts
Status
