ASL 0-11-14 - 2015 TLX - PDI AND NEW MODEL INFORMATION
This Service Letter gives you the information needed for the PDI of the 2015 TLX. It also describes some of the vehicle’s features, equipment, and service information
Applies To: 2015 TLX
Reference: Honda Service Website
PDF:https://www.dropbox.com/s/huy9v8l7ktmktuu/ASL-0-11-2014-E-Rev2.PDF?dl=0
Date of Issue: Aug 12, 2014
ASL 0-12-14 - 2015 TLX: PDI OF THE NAVIGATION SYSTEM
This bulletin provides information for the PDI, including testing, of the navigation system.
Applies To: 2015 TLX With NAV
PDF: https://www.dropbox.com/s/417k2ygdqy9qw66/ASL-0-12-2014-E.PDF?dl=0
ASL J-01-14 - 2015 ACURA PAINT CODES, EXTERIOR & INTERIOR COLOUR CODE LOCATIONS
Each paint company determines paint formulations. For questions about formulas or colour matching, call your paint supplier or one of the companies listed on the last page of this bulletin. The number following the paint description designates the paint process used during the vehicle manufacture: 1 - Two stage process: Clear coat is applied over the colour coat. 2 - Two stage process: A small amount of colour is mixed in the clear coat and applied over the colour coat. 3 - Single stage process: No clear coat is applied.
Applies To: 2015 Acura
PDF: https://www.dropbox.com/s/u3nwvmvvc98g5pb/ASL-B-01-2014-E.PDF?dl=0
Date of Issue: June 18, 2014
ASL B-01-14 - 2015 MODEL TIRE SPECIFICATIONS
Tire information for the 2015 Acura models
PDF: https://www.dropbox.com/s/6eoa37pwud9e9yk/ASL-J-01-2014-E.PDF?dl=0
Date of Issue: Oct 18, 2015
ASB J-22-14 - PRODUCT UPDATE: CROSS TRAFFIC MONITOR ALERT SOFTWARE UPDATE.
Symptoms: On the affected TLX vehicles, the software controlling the Cross Traffic Monitor may not activate the audible alert as designed
Resolution: To resolve this issue, update the meter software
Applies To: 2015 TLX Tech
PDF: https://www.dropbox.com/s/9q9buqfvffi4m1u/ASB-J-22-2014-E.PDF?dl=0
Date of Issue: Dec 19, 2014, revised Feb 18, 2015
ASB-A-09-14: TIMING BELT CHIRPS
Symptoms: On some 2014-2016 MDXs and RLXs, and 2015 TLXs, there is a chirping noise coming from the timing belt area after the engine warms up. The most probable cause is the timing belt contacts the back edge of the crankshaft pulley.
Applies To: 2015 TLX V6 - All.
PDF: https://www.dropbox.com/s/5gg8tuetpoobr51/ASB-A-09-2014-E.PDF?dl=0
Keywords: Engine » Engine Block Assembly » Crankshaft
Date of issue: Sept 15, 2014
ASL-0-05-14: Introducing the all-new 2015 MY Acura Owner Information Kit
Symptoms: Bulletin discusses new electronic owners manuals vice printed copy.
Resolution: Call Acura customer service to request a printed copy.
Applies To: 2015 TLX, RDX, MDX, 2016 - All
PDF: https://www.dropbox.com/s/76ofcnybelasmtn/ASL-0-05-2014-E.PDF?dl=0
Date of Issue: April 28, 2014
ASB-B-1-15: CLUNK FROM FRONT SUSPENSION WHEN DRIVING AT LOW SPEED OVER BUMPS OR TURNING
Symptoms: On some 2015 TLXs, there is a clunk from the front of the vehicle when driving at low speed while going over bumps or turning. The most probable cause is at least one of the self-locking nuts at the top of the front damper/spring assemblies is loose
Affected VINs: L4 from VIN 19UUB1F**FA800001 thru 19UUB1F**FA800907
V6 without SH-AWD from VIN 19UUB2F**FA800001 thru 19UUB2F**FA800488
V6 with SH-AWD from VIN 19UUB3F**FA800001 thru 19UUB3F**FA800008
Keywords: Suspension
PDF: https://www.dropbox.com/s/4qdvzzbh1zpxjr2/ASB-B-01-2015-E.PDF?dl=0
Date of Issue: Feb 6, 2015
ASB-15-027: LKAS Does Not Keep Vehicle in Detected Lane
Symptoms: The LKAS does not keep the vehicle in its detected designated lane and no DTC is stored.
Possible Causes: The front multipurpose camera unit/rain sensor harness is not secured in its clip, causing the camera unit to shift out of its neutral position in its bracket.
Applies To: 2015 TLX - All with Technology and Advance Package
Keywords: Body » Audio/Visual and Communication Systems » Navigation System
PDF: https://www.dropbox.com/s/ky2yztduc20vmny/B15-027.PDF?dl=0
Date of Issue: May 8, 2015
ASB-E-3-15: 8 DCT Transmission Slips or Shifts Hard When Cold
Symptoms: On some 2015 TLXs, the customer may complain that the transmission slips or shifts hard when cold, usually the 1st to 2nd upshifts. The customer may also complain about feeling bumped or jerked after the vehicle has come to a stop. Once the transmission has warmed, it shifts normally. The most probable cause is the ECU setting along with the ODD and EVEN clutches not having been properly broken in
Applies To: 2015 TLX L4
Affected VINS: 19UUB1F52FA800001….. To 19UUB1F52FA80184
Keywords: Transmission
PDF: https://www.dropbox.com/s/77y1ekkzkzgstha/ASB-E-03-2015-E.PDF?dl=0
US Version of PDF. -> http://www.urvi.net/forumfiles/SB/B15-021.PDF
Date of Issue May 29, 2015
ASB-E-08-15: TRANSMISSION END COVER LEAKS (9 A/T)
Symptoms: On some 2015 TLXs and 2016 MDXs, the transmission end cover leaks on vehicles with 9 A/T. The most probable cause is during assembly, the transmission end cover sealing gasket gets torn
Applies to: 2015 TLX - V6 with 9-speed Transmission (9ZF)
PDF: https://www.dropbox.com/s/6lw1a3vjn2gm2v8/ASB-E-08-2015-E.PDF?dl=0
Date of Issue: Sept 16, 2015
ASB-E-5-15: PGM-FI and TCM Software Update
PDF: Canadian version references US TSB 15-034
Reference: Member supplied (@samuel-002) View Reference Image
Keywords: Transmission; K95 Update
ASB-G-2-15 FLUTTERING NOISE FROM BEHIND DASHBOARD
Symptoms: On some 2015 TLXs, there is a fluttering noise from behind the dashboard with the HVAC set to floor or defrost mode, the blower set to maximum, and the temperature set to maximum heat. The most probable cause is under certain HVAC settings, the defrost damper door linkage can flutter. This can be initially triggered by an external impact, such as driving over a pot hole or down a rough road.
Applies to: 2015 TLX - All
Keywords: HVAC
PDF: https://www.dropbox.com/s/t6c6nmw0sbf1kcv/ASB-G-02-2015-E.PDF?dl=0
Date of Issue: Sept 10, 2015
ASB-E-04-15 PRODUCT UPDATE: MIL IS ON WITH DTC P0776
Symptoms: On affected 2015 TLX 4-cylinder vehicles, the MIL may be on with DTC P0776 (A/T clutch pressure control solenoid valve stuck OFF) stored
Applies to: Certain 2015 TLX L4
PDF: https://www.dropbox.com/s/lfwopdhdpi7rbl1/ASB-E-04-2015-E.PDF?dl=0
Date of Issue: June 23, 2015
ASB-E-2-16 TRANSMISSION FUNCTION IMPROVEMENTS: SENSATION OF SURGE WHILE BRAKING, SLOW DOWNSHIFT RESPONSE AT LOW ENGINE SPEEDS, AND OTHER LISTED SYMPTOMS.
PDF: Currently not available or known to exist.
Reference: Member supplied (@MTD)
ASB-J-12-16: VIBRATION FELT IN FRONT SEATS AND FLOOR AT HIGHWAY SPEEDS.
Symptoms: On some 2015-2016 TLX V6 vehicles, vibration can be felt through a broad range of highway speeds starting as low as 100km/h and progressively getting worse as speed increases.
Applies To: 2015 -2016 TLX V6 All
PDF: https://www.dropbox.com/s/bpa0uiv3m7rd9hf/ASB J-12-16.pdf?dl=0
Reference : Member supplied (@vancity_tlx)
Keywords: Vibration
If you have any information concerning these Canadian TSBs or any other TSB, please post information in the comments thread -> http://www.tlxforums.com/forum/tlx-recalls/3545-comments-2015-acura-tlx-technical-service-bulletins-recalls.html
As of 12/01/16
Keywords: HVAC
Keywords: Vibration
As of 12/01/16
