Red or Black instrument visor?
1 - 18 of 18 Posts
· Registered
Greetings! I recently completed a vinyl wrap on my interior and figured that I would share some pics. Door panels and center dash were done with Vvivid dry red carbon fiber and the center console was done with Vvivid dry black carbon fiber. I had the bronze aluminum interior and just do not like it (tech package). I am considering doing the small piece of piano black on the steering wheel in red and the door switch panels on both front doors in black carbon fiber. I want to wrap the instrument visor (above the gauge cluster) but havent decided on black or red yet. I am kind of leaning towards red. What do y’all think? Red or Black?
Mirror Motor vehicle Automotive design Automotive mirror Automotive lighting
Car Automotive design Motor vehicle Red Personal luxury car
Car Motor vehicle Vehicle Automotive lighting Automotive design
Car Vehicle Motor vehicle Automotive design Gear shift
Car Vehicle Motor vehicle Steering part Automotive design
Hood Vehicle Automotive lighting Automotive tire Bumper
· Registered
Wow, I didn’t even think about glare issues. Both the red and black carbon fiber vinyls I have are dry, so they dont have the gloss finish but there is some sheen to both of them. I am going to have to run some tests with that vinyl laid up on my dash and see how bad it might be. Thanks for the input!
· Registered
Tinting the windshield will take care of any glare issue. I’m not a fan of fake carbon fiber so I voted no change.
How dark do y’all go on the windshield for tint? I’m a noob on tinting windshields…I’ve never done that before. Yeah, I tend to agree on the fake carbon fiber, but I haven’t found many aftermarket parts for the 2021+ TLX’s. I know Acura offers the carbon fiber dash/door pieces in gray/black carbon fiber, but I wanted a contrast in my interior instead of all black and that bronze aluminum was driving me nuts.
· Registered
@Splitrip2023 , how’d you wrap the center console? Where did you start from?
I just tried to do mine this past weekend, and had a really tough time getting the vinyl not to wrinkle once I got near the part where the palm rest is. I started up at the top and was trying to work my way down.
I did wrap the trim piece you talked about around the shift buttons, becauseI think the gloss black is hideous, and doesn’t match anything else in the interior. I used VViViD’s Black Ash Vinyl, and like the way it looks.
Reflex camera Digital camera Camera lens Point-and-shoot camera Mirrorless interchangeable-lens camera
· Registered
Discussion Starter · #8 ·
Looks good! As far as wrapping the center console I completely disassembled it. If you search google for the Acura document on how to install the wireless cellphone charger it will show you how to remove the top section of the center console. Once you have it out and upside down you can completely disassemble it until you are just working with the top flat section with the palm rest, cupholders and mouse/buttons removed. At that point its a pretty easy job, just remember with Vvivid to use lots of heat to activate the glue. :)
· Registered
Thanks.
I’ve gotten the center console apart, so I know how to do that. It was more any tips you had for wrapping that console cover, but it doesn’t sound like it. Just take my time with it.
· Registered
Discussion Starter · #11 ·
Thanks.
Just heat and slight stretching as needed to keep the vinyl taught, then I used a gloved hand to rub it down and release any air pockets. I pulled the overlap over the edge and allowed it to adhere to the bottom side so the edge of the vinyl is not stretched. I hope that helps.
· Registered
2021 Acura TLX A-Spec SH-AWD
I hate the piano black as well. I somehow managed to get some micro-scratches in it at some point in the past two years.
· Registered
Did you go off of a tutorial? Or just wing it? Do you have any input on how to do it? Which colored wires to tap in to? Parts list, Etc…
Here’s a post from AZ where someone did it in a new MDX, but it’s largely the same for the TLX.
I used an Anker MagSafe charger that I’ve used for a year without issue. Other parts I used were:
  • 12V to 5V step down converter w/ USB-C output
  • Female-to-Female USB-C adapter (to connect the step down converter to the charging pad)
  • T-Tas or other methods to tap the converter in to power (I tapped in to the lines for the 12V plug in the passenger area). On the factory wiring for that 12V plug, white is + and black is -.
When you pull the console apart, all you do is pull the guts out of the factory wireless charger, glue the MagSafe charger in place, put it all back together, and you’re good to go.
It took me about 90 minutes to do, and I was taking my time.
Motor vehicle Automotive fuel system Electrical wiring Gas Cable
· Registered
2022 TLX Advance / 2023 MDX Type S
That black carbon fiber looks good and you did a good job on the wrap. I feel like the big slabs of red contrast a little awkwardly with the interior, but the black fits right in
1 - 18 of 18 Posts
