1 - 12 of 12 Posts
Hey yall,
I wanted to add some forlights to my tlx, acura quoted 1200 with installation, 700 alone for parts, found the parts for 450ish, has anyone installed fogs on base model? In 2017-19??
Thanks
Hey yall,
Thanks
I think the bezel comes with the oem fog lights and it should be plug and play.
Make sure if they give u the controller (idk what the name )
Thanks appreciate it, im just gonna add remort start for this month will add fogs next month .
@kb1spec A few questions:
1) Was the factory fog light wiring already in place?
2) Did you install the OEM switch?
3) Do you have a link to the lights you used?
4) Was any fabrication or modification needed to get the Sienna lights to fit the Acura trim panels?
Thanks.
No
No
Yes
I brought another set of the trim panel and cut the hole to match up the surrounding of the foglight. I used JB weld and couple L bracket to support and line up the foglight.
Make sure the Morimoto LED foglight have the alignment adjustment.
Sounds like quite a bit of work, but nice results.
1 - 12 of 12 Posts
