1 - 11 of 11 Posts
· Registered
Today my battery died by keeping my radio on too long while cleaning my garage (lol) So no big deal , my wifes car is alongside me... BUT.. when our battery's are dead, the trunk push button does not operate. So my jumpers are in my trunk, and I had to open the trunk manually by this METHOD. Push down on the side towards you, and it will flip open, top removes, then use your car key.
· Registered
· Registered
There is a jump point under the hood....
Great big Red PLUS on top of it next to driver's shock tower. Connect red to that post and black to ground.
There's also a dedicated ground point marked (-). It's the unpainted bolt sticking up a little bit that's to the right of the (+) terminal. Very considerate of Acura, but indicates that a senior engineer somewhere in the project expects that the car will need to be jumped frequently.
· Registered
Very informative, thanks for sharing.
· Registered
Want to bring up this thread. Out of the blue my trunk will not open. I used both of my key fob, inside door trunk release button, and also the outside trunk release button. Nothing works. I even check on the glove box and the switch is On. But for some reason when I am was sitting in my car and press the key fob or the button by the door, I can hear a soft sound of a "click" by the driver side footwell. Not sure what that might be. Only way I can open my trunk right now is the rear deck using the key to open it manually.
I'm thinking to see if I can try to disconnect the car battery and reconnect and see if that will reset everything.
Like to see if there any other insight out there that have this issue.
1 - 11 of 11 Posts
