As the original owner of a 2015 TLX Advanced 3.5L purchased new, my biggest downside of the car was the Auto Idle Stop. I detested my car shutting off and then automatically turning back on. I found this slight delay almost dangerous in many situations, not to mention I believe that turning my hot engine off and on many times will actually short-live the starter, battery and entire engine. Yes, I can easily defeat the system by always remembering to push the Auto Idle Off button at the bottom of my shift console. Even though it has become an automatic reaction of mine: Start car and then push auto idle off button; occasionally I forget and it has always been a nuisance. I have always hoped that there would be a fix for this problem (as there are for other cars). Now there is.
Let me introduce you to the Idlestopper. A little black box with three wires coming out. It will take you about 30 minutes to install and afterward you will never need to worry about pressing the Idle Stop Off button again, unless you want Idle Stop On: which then you would need to press the button.
The Idlestopper comes complete with professional grade crimp connectors already attached to make the install that much easier. Tools required to install are: Some plastic pry tools to remove console trim pieces, a few standard screwdrivers and standard pliers. If you don’t already have, I suggest you purchase a four piece Nylon Pry Tool kit at Harbor Freight for $4.99 as you don’t want to mar or bend any of the interior trim pieces. I would highly recommend if you don’t already have these plastic tools, that you get them for the install.
Bottom line – I highly recommend this product. This is how the vehicle should have come from the factory. How many threads have we seen here and on various sites such as: “Stuck - Vehicle Won’t Auto Idle Restart”: and then that person relates how he got stuck in traffic or almost had an accident.
If you have any questions before or during installation, feel free to post it here in this thread. Below are some photos I took during the install.
Here is my 2015 TLX, the test vehicle. Sorry I didn't have time to clean my garage.
This is the black box with three wire coming out of it. This is what you will get.
This is the $4.99 Harbor Freight Nylon pry bar kit. More than enough for this install.
The Idlestopper comes with professional grade easy crimp connectors. This makes the three electrical connections very easy to do.
Attach the black box under your console with a zip tie so that it doesn't rattle around.
Lastly, everything put back together.
