Help!
I took the rear pads out and connected my diag tool to put the rear brakes in maintenance mode. Before initiating maintenance mode, like an idiot i pulled the parking break switch up instead of pushing it to get the parking brakes to retract. I didnt notice my mistake until the piston in both calipers completely pushed their way out and on the floor.
At this point, i figured no problem. I’ll just remove the actuator on both rear wheels, remove the calipers and manually push the pistons back in. This I did no problem. I them completed changing out the rear pads and replaced the actuator on both sides once everything was back together. I then bleed the brake like usual. Now the brakes seems to be working just fine, but now my electronic parking brake will not set displaying a “rear parking brake actuator failure”. This also triggers other diag codes such as adaptive cruise disabled and blind spot monitoring disabled. I used my diag tool to try and reset these codes, and they just pop right back up as soon as I clear them.
How do I reset the rear caliper actuators or readjust them so i can clear all of these codes and reuse my EPS?
Please help, i feel as though I have tried everything I can think of! Thank for you time..
-Blake
-Blake
