1 - 17 of 17 Posts
Thanks! That's all I needed to know.
It's not listed on the Canadian models. It was the same thing with my 2013 Si. I had to go into one of the menus and enable it. I'm guessing I'll need to do the same with the TLX. Now to find out which menu.
By default Pandora is listed on the second screen page, on US models.
When I received the patch for ELS, I moved Pandora over to page 1.
That's good you have a work-around. I wonder if Pandora will ever venture into Canada.
It's a licensing issue I think. May be too expensive for them to come to Canada.
I probably don't need it with XM and the music on my phone. It's more of a situation where Acura says we can't have it...so I want it. Lol
I used Pandora regularly. It is pretty responsive, actually. With T-Mobile, and unlimited streaming, it makes for a nice feature in the TLX. It works with both Bluetooth, and directly connected to the USB cable, and in both modes, you can even thumbs-up, thumbs-down songs, etc.
Discussion Starter · #9 ·
Yes. The functionality that Honda/Acura provides with Pandora is really good. I enjoyed it in my last car.
I couldn't find anything in the diagnostic menu. This may be more difficult than it was in my Si.
Discussion Starter · #10 ·
I found where it's disabled.
You need to go into the diagnostic menu. (Nav-Back-Menu at the same time)
Once in there select Detail Information and Setting
On that page select Functional Setup
In the Functional Setup menu select Pandora Setting
In the Pandora Setting menu it will be disabled by default. Select Enable.
The alert will say that the change will take effect when the Nav is restarted. Return out of all the windows. Once the Nav is restarted, Pandora shows on the 2nd page of the Audio settings.
I apologise for not being able to put the pictures under each step. I'll need to start using a 3rd party to host my photos for the forum I think. They should get the idea across though.
Great!
Thanks for finding and posting that.
Discussion Starter · #15 · (Edited)
Pandora As An Input Source
@TLX2014 I'm not exactly sure what you mean. I may have missed that discussion and don't know what I'm missing compared to the U.S. system. If you can describe the issue I'll let you know if anything looked familiar.
@MTD I didn't poke around in there too much. The very first time I went in the menu it hung. Nothing would respond. I had to shut the car off and back on. Luckily it came back up no problem. It was a few minutes of sweating bullets though. Lol.
1 - 17 of 17 Posts
