Hi guys, So my wife's '16 TLX passenger door will not lock with key fob or driver master door lock. Manual locking is the only option. Im ready to take the door panel off and troubleshoot, just curious if anyone else had this problem or fixed it. Thanks for your time!
So fuses look good. The lock itself still not moving. Maybe the mechanical movement is disengaged somehow. Ill have to see what the inside of this door looks like. Stay tuned ?⏰
Take some pictures. Always interested when you can peak inside the inner workings of these vehicles.
Maybe try the key in the door. That may exercise the lock cylinder via another method.
Multiple options available:
Locking/Unlocking the Doors Using a Key
  • When you lock the driver’s door with a key, all the other doors lock at the same time. When unlocking, the driver’s door unlocks first. Turn the key a second time within a few seconds to unlock the remaining doors.
Opening/Closing the Windows and Moonroof with the Key
  • To open: Unlock the driver’s door with the key. Within 10 seconds of returning the key to the central position, turn the key in the unlock direction and hold it there.
  • To close: Lock the driver’s door with the key.
  • Within 10 seconds of returning the key to the central position, turn the key in the lock direction and hold it there. Release the key to stop the windows/moonroof at the desired position. If you want
  • further adjustment, repeat the same operation.
