We all like to match things with our TLX and just wanted to make sure everyone is aware that they can purchase matching brake rotors for their car.
Below are pictures of colored rotors for our TLX. They come in a variety of colors: Drilled and slotted in: Black, Blue, Red, Gold, Silver and normal.
Chromebrakes rotors are made from the highest quality raw materials. We use only G3000 premium grade OEM quality castings. Each rotor is perfectly mill-balanced, and double disc-ground giving you an ultra smooth finish ready to install right out of the box. All Chromebrakes rotors are made to match OEM specifications ensuring you will always have a perfect fit. Each rotor is carefully machined using automated CNC equipment. Finally each Chromebrakes performance rotor set comes with an industry first PPC Chromium finish that prevents rust and corrosion, and lasts over 5 times as long as zinc or electrostatic paint-covered rotors. Our PPC Chromium finish provides the best protection in the industry, and provides a stunning visual appearance unlike any rotor you have ever seen! Made from the finest quality brake components and backed with a Lifetime Warranty, now's the time to Go Chrome orgo home.
Front colored rotors per pair = $318
Rear colored rotors per pair = $230
I’ve used their products and found them to be of high quality.
If you are planning a brake job for front or rear, you might want to consider these drilled, slotted and colored brake rotors.
Interesting look. Did they have a picture or two showing them installed?
If not already mentioned, are there Caliper covers to match these colors? Mine look pretty bad!
To answer both your posts: I did not see any pictures of them installed. Personally, I think they would really dress up the wheel. They do not sell caliper covers.
I do not believe the rotors fade or lose their color. They come with a lifetime warranty, so if they did, you could return them under warranty. I don't believe the color is a paint that would wear off or fade.
WARNING!! THESE are not the way they look in the picture! What is a PPC chromium layer? I can't find anything in the industry that explains this process or even explains what PPC CHROMIUM LAYER is. Not to mention the fact that the "chromium layer" is a spray on that literally looks like an industrial paint and it isn't even covered completely on the back side. I am in the process of contacting chromium layer coating specialist's and will post further info on my findings. Check out the link I provided of them. I am also in the process of obtaining a class action lawsuit for false advertising and misleading product description.
SP Performance can color match any vehicle as long as you supply them with the paint code. You can only have this done by calling and requesting it. I saw them post something about it on Instagram and TikTok.
