1 - 4 of 4 Posts
Sorry to hear about your problem. I hope that this code just came on.
The more you drive the car with this code the more damage will be done to the transmission.
Causes for this P2720 transmission code may include:
- Defective pressure control solenoid
- Contaminated transmission fluid
- Restricted transmission filter
- Defective transmission pump
- Defective transmission valve body
- Blocked hydraulic passages
- Corroded or damaged connector
- Faulty or damaged wiring
- Faulty PCM
You need to get this checked right now.
1 - 4 of 4 Posts
