1 - 19 of 19 Posts
I am thinking about upgrading brake pads & rotors on my V6 P-AWS TLX because the performance of the stock ones aren't enough for me. Just not sure as to what I should get, since I am not very familiar with any of the brands.
Do you guys have any recommendations?
Well, how often do you take your car to the track?? >:D
Never really, since I don't want to beat on it too hard, but I'd like to have the car stop faster than it does stock.
Before you change your brakes, you may want to change your tires. Having good brakes won't do you any good if your tires don't have the grip to use the brakes to their full potential.
And if you're tracking the car and just daily driving, why do you need better brakes? If they're worn out and you want to improve the brake feel and shorten the braking distance then sure. But otherwise, do you really need it?
Steps to great braking. By, Me.
1. Tires. Great tires will make for great braking performance.
2. Pads: EBC Red Stuff are fantastic for enthusiastic driving.
3. Rotors: Don't get anything that's been drilled.
4. Stainless steel brake lines.
Really though, try a set of UHP Summer tires. It'll blow your mind.
All of the above.
Better tires first. "IF" anyone make better quality pads, EBC, Stoptech, etc makes pads, those might be a start. Cross drilled rotors look great, but thats about it on a street car, slotted chews up pads. SS lines, pads and fluid that wont boil.
I wouldn't run higher temp brake fluid on the street, since it's optimal when the brakes are heated up and you'll never reach that temp by daily driving.
i hear you tho, i feel like the TLX is a bit under-braked. i'm working on a big brake upgrade, using fresh rebuilt TL type S brembos, and getting a bracket made so that they will still clear the factory 17's; if anything clear them with a 5mm spacer.
another option i'm looking into is a stop-tech big brake kit, i just have to get off my butt and print out the measuring template to see if they will clear the wheels; also D2 has a big brake kit as well. i'm going one of these three routes soon so i'll report back.
oh and having tracked with daily driving blank, slotted and cross drilled rotors, personally i like slotted rotors the best. MTD is right they do eat pads but...meh
Discussion Starter #9
Putting new tires on the car is already in the plans. I am either going for Pilot Supersports or potenza s-04 pole position. Would like to hear your guys' input on this.
I have been looking at EBC pads & rotors, might go for those.
I had Pilot Supersports with stoptech x-drilled and slotted rotors with ceramic pads on my civic si. LOVE them.
I am now waiting for them to make OE fitment for the TLX.
On a side note, it's sad that my 60% tread Michelin Alpin PA3 snow tires has better traction in rain and dry than the stock LS2's... I almost wanted to just run them all year round...
While the Super Sports are expensive and only have a 60K Kms treadwear rating, I find they are the best tire I've ever had on a vehicle. They really transform the car...although I only had the LS2s to compare them to on the TLX.
I agree with @Vancity_TLX in that my Michelin X-ice winters are better than the LS2s as well.
Discussion Starter #12
Is there a noticeable difference in road noise between the stock tires and your super sports?
My biggest problem with the stock tires is that since I have the v6 FWD model (still pissed I didn't get the SH-AWD), the tires even with traction control enabled easily spin out from a stand still. Hoping to fix that issue with my next set of tires.
Does stoptech have nothing available for the TLX right now?
Stoptech has the OE rotors; not slotted or x-drilled
Seeing your user name and I assume ur in Vancouver? It yes then it's AWESOME! We have a FB and whatsapp group for Vancouver and nearby cities' TLX owners! And we are gonna have a meeting on the 20th, which is the day after tomorrow! Let me know if interested, and my Whatsapp:7786812108 Shoot me a message and you shall have connection to all of our group members!!! Thanks:)
Discussion Starter #17
I bought some new Yokohama tires to replace the Bridgestones that came with the car. The difference is super obvious. The car now grips significantly better during acceleration, corners faster with no squeal, and stops much faster. Still might upgrade the brakes eventually though.
I went with SP Performance Rotors on mine and love them. It's been about 6 months now and they still feel like new. Even with my heavy foot and daily heavy traffic routes!
Definitely check them out if you are still looking.
Old thread, but has anyone tried opening up the front bumper air ducts to bring more cooling air into the front rotors?
1 - 19 of 19 Posts
