Anyone hardwire a radar detector yet? If so did you tie into the fuse box or the mirror console? If you have instruction on what fuse or how to tie into the wires around the mirror that would be great.
My old radar detector has a radar detector detector detector and can hide itself...even though the VG2 isn't really all that common these days.Aren't you guys worried about cops that might have a radar detector detector?
I'm not sure which one of the mounts would work best for me. I have a TLX I4 with the Tech package...but none of their examples look exactly like my mirror. I am attaching a picture of what comes on the TLX Tech.I have a Valentine one with the Savvy option https://store.valentine1.com/store/ which gets its power by plugging directly into the OBD port. I am going to attach the detector to the mirror via an aluminum bracket BlendMount Radar Detector Mount Escort Beltronics Valentine One . This way it does not need to be hard wired and you can still use the same detector in multiple vehicle. I haven't set this up in my TLX yet but have it in my 4Runner and my wife's MDX. In those cars I was able to run the wires into the protective sheath of the rear view mirror , around the plastic border of the windshield , down to the OBD port and fully conceal it. The Savvy works great because it automatically mutes the detector after the first warning, very useful now that there are so many false alarms on the hwy due to radar systems like active cruise control.
Sent from my iPad using Tapatalk
Disregard my last post...Looks like the Advance Package mirror is incompatible with blend mount. Acura Blendmount Radar Detector Mounts As my mirror looks like this one: BLENDMOUNT ID#-ACU-200
Awesome work!I just hardwired my Passport Max2.
I used the smart cord http://www.amazon.com/gp/product/B003PJ6QPQ/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
An Add a circuit
Amazon.com : HitCar Car Vehicle Circuit Blade Style ATM APS ATT Low Profile Mini Fuse Holder Fuse Tap With 5AMP Fuse (Mini Size) : Electronics
I did not drill any holes. I fed the smart cord under the steering wheel and then used the velcro tape supplied to put it next to the wheel opening.
I fed the cord that connects to the detector up the A pillar. I just pulled on the section near the opening of the door and was able to feed the cord up to the top. The top where the roof liner is has a gap so I just fed it in.
I attached the circuit with two 5 amp fuses to the open slot as shown in the picture.
I removed the left hand side of the dash panel, it just snaps off. Start on the bottom right and work upwards.
I then unscrewed one of the bolts as shown an attached the grounding wire.
The detector now only comes on when you start the car or you press the start button twice when you just want accessories on. It was very easy and only took about 15-20 minutes.
Woohoo!For those of you that were/are interested in the Blendmount Mirror Mount, I have an update on the design status for the TLX Frameless Mirror.
The guys at J28 Design sent me a beta version of the mirror mount last week for the TLX Tech and Advance models that have the new Frameless Mirror. They sent two models (just a slight difference in the mid-section) that I've been testing and I've provided them feedback on my experience (which has been great).
One issue I've seen is that the Escort Max RD can take a little longer to acquire the GPS signal because the electronics module above the mirror restricts the signal somewhat. I've always been able to lock on a signal, but sometimes it takes longer than normal. It also appears to hang a little further below the mirror than the other Blendmount models I've used (one for an '04 TL, and another for a '14 MDX). That's more due to the design of the TLX mirror than the mount, it really couldn't be much closer to the mirror and still allow you to easily remove it.
They have sent me a couple more top and mid-section beta pieces today, so I'll try them out and see if it improves the GPS acquisition. I'll try to keep you updated as I hear more on the final design for the TLX Frameless Mirror. I've attached a couple of pictures of the beta unit I'm currently testing.
Sir, when you talk about opening the A-pillar from the door opening, did you remove the whole trim? Did you have to take off the weather strip to do so?I just hardwired my Passport Max2.
An Add a circuit
