1 - 5 of 5 Posts
I am enjoying the factory system, however it lacks low end... looking for a little chest punch when Jay Weinberg is on the drums!
Has anyone added an aftermarket sub to the 2021 system yet?
I know I will need a processor along with the amp & sub to properly integrate, however I'd like to see if anyone has had anything installed yet?
Thanks !
Make sure you use a 2 ohm sub. Lot come with dual voice coils rated at 2 ohm per, utilize only one 2 ohm coil. The sub mounts from the top, so you have to remove the rear deck cover.
Yeah, i'll be doing aftermarket all the way around. More than likely the Hertz processor & JL Audio sub & amp. Probably do a fiberglass enclosure with a 12w6 in it.
Thanks for the advice though!
1 - 5 of 5 Posts
