1 - 10 of 10 Posts
Hi, I am looking for detailed spec of 21 Type S wheel spec, such as offset and center bore, because I am trying to buy a aftermarket wheel. Thanks.
Thanks man, do you have the post address that I can check?
You have to be a member of the group to see it but: Facebook Groups
"So after all the detailed engine and underneath pics I posted yesterday, people had lots of questions. The biggest ones were will the 19s from say, my A-Spec, fit over the Brembos on the Type S, as well as bolt pattern questions. So I came in to work even earlier than normal to swap a wheel between mine and the S. The answer is YES, they will fit/clear, and same bolt pattern as expected of course. Here’s a bunch of pics, and one video at the end of me spinning it by hand. Yes, even the wheel weights clear the caliper too. So yes, it all fits!
It’s damn close, but it fits."
He also states the knuckle is the same so Brembos from Type-S will fit/mount on all other trims of TLX.
2021 TLX Type S (had 1994 Integra GSR 4DR)
I am taking delivery of my S tomorrow, the 19 inch from the regular TLX fits and I am having the Tech package wheels swapped (NJ pot holes destroy excessively low profile tires). We tested them and they do fit and leave about 1/2 inch between the calipers and the wheel. (I can post pictures if you need them)
However for winter I wanted the Base model 18inch wheels, and they are too small to fit over the calipers.
You think it is possible to run the same Performance Wheels/Tires set up from the TYPE-S on the TLX Aspec AWD (2022) without having any powertrain and/or issues down the line.
100% bigger is never a problem for clearance unless you are sizing up the entire diameter/width. Type-S are 20" but overall wheel/tire diameter and width are the same as A-Spec 19s
1 - 10 of 10 Posts
