The factory has messed up your wiper arms. I have seen some cars like mine that will have this problem. Some have even dm me that they have the problem as well. The wipers are basically over bent and they cause wiper noise and make your blades wiggle/bounce. You need to check that if your 2022 tlx has this you need to call corporate. Somewhere in the factory has messed up the pressure of the wiper arm and has over bent it. The way to check if you have/ will have is by checking your wiper blades. If your wiper blades are straight to the glass meaning no bend or curves on the glass you are fine. If you blades look like this ( or / on the glass, you will get this problem.
