Hello, I'm trying to get some guidance from the community on what might be happening with my daughter's 2015 2wd TLX 4 cyl. I've seen multiple posts with similar issues, but not exactly what I'm seeing.
Yesterday morning (around 8 degrees F here), she pulled out of the driveway and a few miles down the road the car began to stumble and multiple display messages (brake system failure, emission system failure, parking brake system failure, etc, etc) were presented along with the CEL flashing. She was able to get to our house with the car apparently in limp mode. My first thought was the battery, as the car had acted similarly about 42 months ago when the battery went south (the car was fine after that battery change). I checked the battery and it was a solid 12.4V with about 14.3V with the car running. The car cranks fine, no hesitation. I disconnected the battery for 20 mins and when I started it back up the messages were gone, but the car was missing badly. I then pulled a P0303 (cylinder 3 misfire) from the pending codes. Someone told me that multiple failure messages will be thrown up when a car goes into the limp mode, so the core problem may well be a bad coil. This doesn't make sense to me, but I'd like some thoughts on where to start with this. I've found comments on about six different possible causes, from the high pressure fuel pump to toe-in actuators, so I'm trying to zero in. Could a bad coil alone cause the "Christmas tree" failure messages and limp mode issues? Does it make sense to swap the cyl 3 coil to a different cylinder and see if the failure follows that coil? Thanks
