1 - 9 of 9 Posts
Hi,
I want to turn off the Lane Departure beeping noise once and for all. Is there a setting in place where I can configure this?
Thanks,
humm.. I tried that .. I dont think that is the solution.
I believe there is a button under the left side of the dashboard where you can disable the Lane Departure Warning
See screenshot below.
25568
If that button isn’t working to turn off the lane departure warning (including the beeping) then there is something wrong with your car.
Unless we are not understanding what exactly you are trying to do?
I agree with Mr. Moo. That should take care of it unless what you are describing is something different.
Reactions: TrickVert
2020 TLX, 3.5L, Tech package, Modern steel metallic
Part of the confusion may be in your description of the issue. You appear to be asking about "Lane Departure". On my car (2020 tech) there is a Road Departure Mitigation (RDM) and Lane Keeping Assist System (LKAS).. different systems. Are you, perhaps, mixing the two in your description?? If so, which one are you trying to kill?
1 - 9 of 9 Posts
