This is brand new set of coil over from SCALE. Very high quality paid $1350 for these, with the upgrades black rings, stainless hardware and sealed bearing, these are for the regular drop. Stock height to 3in. The regular version is designed to allow you to adjust the ride height from OEM to approximately 3 inch lowered. It also keep comfort level close to OEM ride quality. Added the stainless steel hardware and the seal gravitational bearing.
Website below to check them out
scalesuspension.co
scalesuspension.com
Features - the threads are all marked so makes easy adjustments.
Suspension Type Front MacPhearson
Suspension Type Rear Multilink
Number of Valving Selections 24
Aluminium Type 6061-T6 CNC-Forged
Spring Color (Default) Black Gloss
Powdercoated Body Black Gloss
Anodized Body Black
Body Diameter (mm) M52X1.5
Internal Design Monotube
Shock Oil Type Synthetic Shock Oil
Pressurized Charge High Pressure Nitrogen
SCALE - Innovative Racing Suspension
High-End Conception and not only in appearances. Molybdenum rods, mono-tube design
ACURA TLX 15-20 INNOVATIVE SERIES COILOVER - SCALE suspension.com
The Innovative Series is the best choice for street use, spirited driving and occasional track use. This coilover suspension provides improved performance while keeping really good comfort; it offers everything you need to enjoy driving your car.The regular default version is designed to allow...
Anodized Body Black
